Bandsaw (old) (Needs Repair)
Certified trainers for this tool are: James McKeown, Ken Brown, Mark Zander
This is a Rockwell 14" wheel, 93 1/4" blade bandsaw.  It is capable of high speed wood cutting and low speed metal cutting, but we use it exclusively on the high speed setting.
It has a 2 speed clutch at the back that should ideally let you switch between high speed wood cutting and slow speed metal cutting.
Owners Manual
Consumables:
We typically order replacement blades from R&D Bandsaws (http://tufftooth.ca)
  • The speed clutch is tight, requiring a lot of force to properly set.
  • needs oil
This item came from Peter Clark (Simon's Dad). It was used in the brake-lining industry since new, cutting brake pads in half for testing purposes.  It now belongs to Diyode.
Rockwell 14" Metal cutting bandsaw
Model : 28-300
S/N : 313580
Blade broke on November 3rd
- Seth England Nov 03 2019
If I plan on cutting plywood and/or dimensional lumber in straight lines, a circular saw is a versatile tool for my arsenal. With a few tricks and techniques, I can make nice, straight, square cuts without having to own several separate, bulky tools, like a table saw, and a power miter saw. mitersawexpert(dot)net
- David M. Goldstein Jun 19 2015
Thanks a lot for providing instructions on bandsaw.
- nguyen thi duong Apr 29 2015
This is totally awesome. This machinery is very useful and helpful. Rest assure that this is a highly recommended machinery.
- le trong linh Apr 19 2015
